Originally Posted by mattebury
That's in the dash programming.
From page 126 of the owner's manual:
Autolamp timer presets
This feature keeps your headlights on for up to three minutes after the ignition is switched off.
1. To disable/enable the autolamp delay feature, select this function
from the SETUP control for the current display mode.
2. Press the RESET control to select the new Autolamp delay values of 0, 10, 20, 30, 60, 90, 120 or 180 seconds.
Thanks, but my truck has the standard message center.....not the optional message center. IE, I only have the select/reset single button....not the Setup/Reset/Info 3 button cluster. I have read the sections in the owners manual. For the standard message center it does not mention squat about the timer....only in the optional message center section. My 2010 manual is a little diiferent than the 08 (as page numbers do not match yours) but I am looking at the section you mentioned it is says for trucks equiped with the optional message center.
Also, I looked in the section regarding the instrument cluster and that is where I found the instructions for the optional one.
Does anyone know if these settings can be changed on a truck with the STANDARD message center?
Thanks guys,
Jerry
Black 2010 Ford F250 XLT Crewcab Longbed 4x4 6.8L V10. Special Ordered. 295/70r18 Nitto Terra Grapplers on black powdercoated stock wheels, Harley Davidson Edition headlights. FX4 Grille. Recon smoked cab lights and mirror lenses. Factory bumpers and nerf bars have been powdercoated black.Husky Mudflaps,custom black 4" exhaust, AirAid intake, X3 tuner from 5 Star Tuning, AutoVentShade door sill protectors. Soon will black out the badges.
