High Capacity Trailer Towing Specs
Ok guys, I've got a tech question for you...
When a 2005-2007 F-550 with an automatic transmission is equipped with the High Capacity Trailer Towing Package, what mechanical changes set the package apart from an F-550 without this option? I know the GCWR jumps from 26,000 lbs. to 33,000 lbs. and the axle ratio is a 4.88:1 limited slip ratio, but what else is there? Springs, shocks, tranny cooler, engine tuning?
I have found a truck that may suit my needs but it lacks this option and I'm curious if I can add the components to equip the truck as if it left the factory that way.
Any help is much appreciated. Thanks in advance.
Patrick
