Diesel Forum - TheDieselStop.com - View Single Post - 7.3 hard to start when hot
Old 11-03-2009, 10:46 PM   #3 (permalink)
DieselDually1993
if you pour water on make sure it is luke warm, not cold. cold water on hot metal = bad news.
I had the same problem you were having and when I knew I was going to have trouble I would use an electric fan (safer than water). Just let the fan run for about 15 minutes and you would be good to go.
Will it start after about a 5 minute or so shut down? I've heard that diesel fuel acts as a coolant and the real problems occur after say a 15 minute shut down. This is when the heat from the engine block gets up into the IP and shuts it down.
1993 F350 E40D 7.3 IDI 169k stock stock and more stock.
DieselDually1993 is offline   Reply With Quote
