11-03-2009, 11:17 PM
#5 (permalink)
Yes, you want to separate the water from the diesel (instead of mixing it). The water will mess up our injectors. You can use fuel additives to keep the fuel from gelling, add lubricity, etc, but don't get one that will mix the water and fuel (i.e., contains alcohol)! Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
