Diesel Forum - TheDieselStop.com - View Single Post - detroit diesel 60 series power loss
Old 11-03-2009, 11:25 PM   #2 (permalink)
Gone Fishen
You need a new shop.
In the AM get in the truck and pump DOWN the air to about 60, start the truck and go thR side and watch the little piston at the turbo. [turbo-actuator]. The fan will shutoff about the same time as the turbo shaft will rise. You can hear the turbo spool up. If it doesen't, or pulses, or jijjles a lot you have 1 of 2 problems.
#1- you need a new V-pod, found at the lower RS of the engine block by the oil pan rail. crawl under and look for it.
#2- the turbo actuator leaks air, or does not respond to the air supplied from that V-pod.
Air TO the V-pod MUST be greater than 100 psi, air FROM the V-pod TO the turbo actuator will NOT exceed 74 psi. Basically greater pressure then faster turbo speed.
Sounds like you need a new V-pod. careful, I have gone thru 3 on 1 truck to find a good one. They are covered with a 1 year warranty though. Save the receipt.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline   Reply With Quote
