Diesel Forum - TheDieselStop.com - View Single Post - 12V92 RATrod
Thread: 12V92 RATrod
Old 11-03-2009, 11:32 PM   #4 (permalink)
Gone Fishen
Just worked on one in a gen set. Heads are the same, you will need to ask a GOOD parts guy about the cams. You will need 12 Injectors, 1 governor housing and 1 slave governor housing. Racks, rack rods, look into the piston/liner thing also. Gear train should be the same BUT maybe the blower drive gear might be different. Also check on the correct turbo's. Sometimes turbo's are different due to the precise air/fuel mix. Fuel jumper lines and fuel stands. I will think on it tonight.
Also worked on my first 24V-71 gen set. What a nasty engine than is. There is a lot of BS on that engine. Sounded good.
Still like the old dirty dozen, 12V 149's are cool also. those 2 engine will make love to you on the dyno.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline   Reply With Quote
