Diesel Forum - TheDieselStop.com - View Single Post - 01 f-350 7.3 powerstroke
Old 11-03-2009, 11:45 PM   #2 (permalink)
woodnthings8
woodnthings8's Avatar
Here is some info off of ITP Diesel, LLC Autoenginuity page:
For 99-03 7.3L, another way to use AutoEnginuity to see if there are problems with a particular cylinder is to monitor the "Cylinder x Change Rotational Vel" or "Percentage of Crank Deceleration" PID (also commonly called PERDEL). This PID exists for all 8 cylinders and is a representation of crankshaft velocity change (decrease) at the time the cylinder is firing. Ideally, these should all read 0%. Any cylinder consistently reading more than 3-5% change in rotational velocity is suspect and should be further examined. Note: Engine should be fully warmed up before checking PERDEL data.
On the truck that read 0.0....was the oil temperature up to operating temp? I know it will read 0.00 until the oil temp gets to around 135 degrees or so.
What numbers are you getting for PERDELS on each cylinder? Under 5% is usually ok from what I have read. and the new recall CPS usually throws a few cylinders higher than that.
As far as the running rough, have you changed the oil in the last 3-5k miles? These engines need clean oil and more than a few times I have taled to people that changed the oil and the truck starting acting "normal" again.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
