11-04-2009, 12:54 AM
#5 (permalink)
My guess is you will also want an intercooler or water injection pending tire size and if you are towing much. Did you install the 3:73's? As I recall 97's only came with 3:55's or 4:10s. In terms of E-fuel you might look into a DIY using a 6.0 litre integrated pump water seperator, fuel heater and water sensor.
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler.
http://community.webshots.com/user/jcart44
