did it on my 05 350 KR i would guess all the wires are the same but IDK 100%? its vert easy if yo have the upfitter switches. you have to remove you fuse box "4 screws" and fine the wire loom with the 4 orange and ---- (+ 4 diff colors for the 4 diff switches) then all you have to do is fine the lose idle wire and boom your done. but i would have to look and see what color the idle wire is on my trk assuming there the same.....
 2005 F-350 King Ranch FX-4 CC long bed
2in level kit...airade intake with 4micron sock...superchips....sinister coolant filter.....blue spring update....ranch hand wrench ready front bumperreplacement.... installing glowshift gauges this week....EGT,BOOST,TRANS TEMP,FUEL PSI. with quad gauge pod A-PILLAR (DONE) 4IN turbo back cat delete
In the Garage
1995 F-150, 460CID, 9in currie rear, C-6 trans, 4.56gears, 23in susp travel.
2004 Expolrer 4.0L
Coming soon
2012 BOSS 302 (If the wife dont kill me)
