Diesel Forum - TheDieselStop.com - View Single Post - Coolant Flush - VC9
Old 11-04-2009, 08:20 AM   #3 (permalink)
bismic
It took me 5 distilled water fills to flush everything out.
As SeaTowJoe said - you filled it to about a 30% concentration.
I would recommend draining again, adding Distilled water and the VC-9 and circulate by driving and getting the engine hot. Ford insists this is very good for the system (and I assume it is safe since I have not read anywhere that people are suspecting that it caused problems). They say it can get rust and precipitated deposits out of the oil cooler - but it will never resurrect a plugged oil cooler.
Edit - it is VERY important to your truck to have AT LEAST a 40% concentration - even better to be at 50%.
Mark
bismic is offline   Reply With Quote
