Diesel Forum - TheDieselStop.com - View Single Post - Clatter noise from transmission in neutral.
Old 11-04-2009, 11:14 AM   #8 (permalink)
pschand
pschand's Avatar
Originally Posted by speeddemon31176 View Post
The troughs that you are speaking of are the flats that the clutch fork is supposed to slide into. I hope that is how you put it together. That keeps the outer half of the throw out bearing from spinning on the shaft.
Uhoh..... It looks like i'm gonna have to pull the clutch fork out.... I really did'nt see how the clutch fork attached to the troughs. I should be able to put some grease on the shaft at this point... I am assuming that I can hook the clutch fork back up to the throw out bearing correctly without having to pull the tranny right??? I might go to NAPA and see if they have a throw out bearing and clutch fork that I can look at in the store to see how they are supposed to hook togeather...
06/F350/6.0L/CC/4x4/LWB/AT/SCT XCAL2
My Old 96 Truck
pschand is offline   Reply With Quote
