Can you post the PN from IH for the CPS. I have had three different CPS in my truck at one time or another and none ever came with a shim. The Blue IH CPS will retard the timing which does make the engine quieter but the tradeoff is also a slight reduction in power.
This was documented a few years ago when someone ran some comparisons using a Dyno. It should be in the archives, somewhere.
Can you also explain the Banjo Mod?
2OOO F-250 4WD Crew Cab, 248,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator H2O Pump. AIS Severe Duty Filter, Switched 10K MOD, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Optima Redtops,Mesa, Arizona
