at idle and cruising you should be in a vacuum .Engine will be sucking more then turbo is pushing. only under acceleration or with load will you overcome negative air preasure ( vacuum ) with positive ( boost ) so you should be at zero most of the time. I THINK ? So if your gauge stays at the positive side all the time ( shows boost ) there is something wrong with gauge.
