You may have a defective ignition switch on the steering column. Not the key cylinder either. It is located under the dash on the column. Look and see if it has melted connections etc. and replace whatever is damaged. Ford has had problems with them for years. It is the only other thing I can think of in the system that could cause it short of a bad starter.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
