Originally Posted by teamroper60
True. IIRC however, the engine warranty is called the powertrain warranty in my warranty stuff, which is why I called it that.........
Semantics aside, if he falls in the categories I listed, his headgaskets should be covered....
I see so much confusion about coverage that I am very sensitive to semantics when it can be misleading. So (up front) my apologoies for being a PITA. I have copies of all the warranty books and they do say Diesel Engine Warranty. Your coverage information is spot on, and hopefully no one expects coverage of the tranny, driveshafts, differentials, etc.
Mark
