Diesel Forum - TheDieselStop.com - View Single Post - Engine, differentials, and maybe tranny swap question
Old 11-04-2009, 08:52 PM   #6 (permalink)
rsr911
rsr911's Avatar
Originally Posted by Tricks87 View Post
well sure sounds like you know your stuff lol, i like the idea of the frame swap would probly save a heck of alot of time, but the 91 is a extended cab long box i believe and the 92 is a regular cab long box, would i be able to cut the frame down? or is this just alot of work in general?
Cutting and sectioning a frame is not something I'd recommend to anyone who isn't an experienced welder. Why is the 91 a parts truck? bad title? major damage? What about just fixing it up and selling the 92? Even better if the body and bed are bad on the 91 find an extended cab 150-350 and swap that body and bed onto the 91, less headache and you can still sell your 92 to offset the cost.
To give you an idea on what can be done with time, creativity and a little money: my Porsche was originally a 1966 912 4cyl car. It now has been converted to a 911 with a 1983L 3.0 6cyl. I used carbs from a 2.2L 6cyl and put in larger venturis and jets. I used a 71 911 trans because it fit best. It has tie rod ends from a turbo, front and rear suspension from a 90's 911 Carrera, flairs from a early 80's SC and a 1974 IROC body kit. "S" brakes front and rear. It weighs 1850 empty, makes 200rwhp and goes like stink. I collected everything on ebay, enthusiast forums and swap meets.
If you have a car to drive during the process this could be a really fun project.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline   Reply With Quote
