Diesel Forum - TheDieselStop.com - View Single Post - still getting CEL after installing boost relief valve
Old 11-04-2009, 09:47 PM   #2 (permalink)
woodnthings8
woodnthings8's Avatar
Is the light staying on or does it go out after a few minutes? What code are you getting? If you are getting P1211 that means the ICP pressure was less than desired for a set amount of time, usually a few seconds. Is the light coming on at about 24-25 psi of boost?
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline   Reply With Quote
