Diesel Forum - TheDieselStop.com - View Single Post - Just bought a '94 powerstroke
Old 11-04-2009, 11:25 PM   #18 (permalink)
LarryR
Originally Posted by speeddemon31176 View Post
I forgot to mention that after you do the adjustment take it out for a test drive ana make several turns at intersections to verify that the wheel returns back to center(straight) on its own. If it doesn't jack it back up and loosen the jamb nut and turn the screw with the allen socket counter clockwise about an 1/8th turn and tighten jamb nut and test drive again and repeat procedure until truck returns to center on its own. You probably won't get every bit of play out depending on how long it was like it is now but it will be seriously improved.
Thanks for the additional information. I plan on doing the adjustment this weekend. I cant wait to get working on it. The long drive to and from work means I have little time to do anything during the week.
Larry
LarryR is offline   Reply With Quote
