Diesel Forum - TheDieselStop.com - View Single Post - wiring diagrams and other service info
Old 11-05-2009, 01:06 AM   #6 (permalink)
rsr911
rsr911's Avatar
I found the main library to be an invaluable source, they had professional service manuals for nearly every vehicle you can think of going back 20-30 or more years. I made copies of all the appropriate wiring diagrams. Those diagrams have the color codes for every wire. My are for a van so I doubt they'd be much help to you.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline   Reply With Quote
