Diesel Forum - TheDieselStop.com - View Single Post - New Guy Here looking for some help.
Old 11-05-2009, 03:15 AM   #5 (permalink)
boomboom
boomboom's Avatar
what kind of boost are you getting, or do you not have one of the two most important gauges that should be in your truck? the other being EGT. Sounds like your not making boost or maybe a boost leak somewhere. Check your intake,turbo,intercooler hoses for leaks ?
boomboom is offline   Reply With Quote
