Originally Posted by michaelwooten
Hey guys,
Been around here a while but have had no new issues until now....so here we go.
Drove all morning and the truck ran fine. Stopped at the local tackle shop and after I got back in the truck it started fine, but kinda was slow to go for some reason. I started driving and once I reached speed and I took my foot off of the gas, it did not respond very well when I put it back to fuel, blew a big cloud of black smoke and finally started going again. Kept doing this for the 10 mile trip home and after I got halfway home the check engine light came on. Would only do this on takeoff and cruising speed. Had bad turbos in my other 03' but did not sound like this...any ideas?
Got an appointment at Gresham Ford in the Morning but was curious what you guys thought.
It could easily be just an EGR valve. I assume you are still under warranty. If so, and it is your EGR valve, your emissions warranty will cover the repair 100% - so you pay ZERO deductible!
Mark
