Diesel Forum - TheDieselStop.com - View Single Post - Spare Tire Carrier
Old 11-05-2009, 08:11 AM   #4 (permalink)
therabbittree
therabbittree's Avatar
I want to make a pivoting or tilt down tire carrier ie you could lower the tire down to the ground and unbolt it on the ground.. and same with reloading it..i may mount a small boat winch to lift it..plus that way my wife could change the tire if needed.. because she isn't gonna be able to lift a 285/75/ 16 spare out of the back of the truck and or take one off a spare carrier either.. something to think about..I could do it, obivously... but if your spouse drives the truck ..thats something to think about..even picking up the flat tire and rim and putting it into the back of the truck would be a huge struggle for a small woman..so I hope my idea works.. I will post pictures when I do it..probably this summer though. I plan on one board air system too so a impact would be available too..should be sweet
thanks,
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline   Reply With Quote
