Originally Posted by woodnthings8
You may have to loosen the up pipes to get some extra wiggle room. You will have to make sure everything is good before tightening back down. Usually the up pipes dont do real good after years of heat cycles so you may have to replace them if you notice the pipes are irregular shaped at the donuts. Good time to upgrade to bellowed up pipes!
Will I need to loosen at the upper and lower mounts?
Dave C.
2003 F350,7.3,Shadow Gray,CC,SB,Auto,4X4,FX4 w/Zoodad,AFE Magnum airfilter,Bank's Monster Exh,ISSPRO Boost/Pyro combo,in-tank/pre-pump/harpoon mods,TriCum/Sonnax mods,SCMT @ 90hp,ProComp traction bars,203 stat,velvet-ride shackles,Transferflow 46gal tank,stainless HPX,WhiteKnight lights,powerstrokeconverters tri-disk -200 stall,Turbomaster wastegate controller,ATS ported housing, britebox+FLC
PS:things I wouldn't buy again:velvet ride shackles,whiteknight b/u lites
