corrosion problem.
Originally Posted by angst
I can only go about two months between thorough cleanings of the battery terminals. They are constantly building corrosion on the wires or bolts.
I have put baking soda on them many times and they should be neutralized of any acid sitting on them.
Is this corrosion an indication of something going on like a short or other similar problem?
Very often corrosion is caused by gas coming up around the battery posts. Try using those impregnated felt rings over the posts before replacing the terminals. Cheers.
Brian.
94 PSD. Supercab, LB. 5spd.
Autometer oil & coolant temp gauges.rancho 9000
shocks.Smitty tube step bars.Pulsetech battery
maintainer.Rhino spray on box liner.Towing mirrors.$20 exhaust brake.Inside/outside thermometer.Radio shack CB.Still a building.LUK single mass flywheel and clutch.DIY oil bypass filter.DIY air filter.DIY coolant filter.
