Originally Posted by Tweintz
It was done under warranty by a real good ford tech. They would not magnaflux, only check for warp. If warped they order a new head. I will have to run it hard again this week and see if it still does it.
Well, in your case, did they use new heads or the originals? Cracks in the heads are not uncommon. If they used your originals and didn't check them for cracks (magnaflux), then you really don't know if they were cracked or not. Brand new heads that are not flat is also not unheard of...
Good luck.
Toreador Red/
Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
pics
#43
SLAPS President and Webmaster
