Diesel Forum - TheDieselStop.com - View Single Post - My E40D transmission started shifting unevenly and the "off" light is flashing
Old 11-05-2009, 12:45 PM   #9 (permalink)
blageurt
blageurt's Avatar
It probably is the VSS which will throw a PO500 code. I changed my sensor and the connector . It still flips out now and then. I need to replace the wires now since there is a connection /connectivity issue. When I turn left hard sometimes it will go off. Spring Time I will deal with it. The sensor is in the rear end on Top. The connector I got from Ford. Good Luck
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline   Reply With Quote
