Some leakage is typical but a leak is a leak. Usually installing the gaskets is the simplest and least expensive option. I say "usually" because you never know when you will encounter a seized bolt that breaks or a manifold that is unknowingly rotted away. Consider new bolts with the gaskets on this project.
Ford Master Diesel Technician
Diesel Technician Society
