Diesel Forum - TheDieselStop.com - View Single Post - EGR cooler delete + new oil cooler= no boost
Old 11-05-2009, 01:53 PM   #1 (permalink)
barnbridge
Truck started fine, seemed to run OK. Took it out for a spin and no boost. The pipes coming and going from the turbo to the intercooler aren't warm as they normally are. I rechecked all sensor plugs are connected. What could be causing no boost, it worked fine before I started this project?
~2004 F-250 Quad cab long bed, 6.0L PSD,4x4 ~Torqshift Trans
~Arizona beige,tan interior
~Running boards w/custom Piranha LED lights
~ARE bedcap, Bedrug
~Foglight/high beam mod,BriteBox,HD light harness
~Zoodad mod, High idle mod
~Coolant filter, Oilguard bypass filter, Fumoto
~Isspro pyro,trans temp,boost in A-pillar
~Marinco Block Heater Receptacle
~Bodiak front hitch
~Mag-Hytec rear diff cover w/6qts syn fluid
~250 watt oilpan heater
~Scanguage
barnbridge is offline   Reply With Quote
