Used to be called the Mercedesshop but now it is Peachparts (who knows the guy is from GA). Lots of good info there. The 87 had the 603 engine as I recall which had the nick name "rodbender". Had a flaw in the heads that was usually instigated by overheating. Be carefull esecially if it is not running. Check the oil for coolant and the coolant for oil. Here is a link to the site.
Good luck.
PeachParts - Mercedes Parts & Tech Info
1989 Centurion Classic 350 4X4 (F-350 4door Bronco), W/93 7.3L IDI non-turbo, ZF 5-Speed(LUK)/BW 1356/Dana 60/Sterling 10.25, 3.55, Hypermax Turbo/Intercooler, 3 1/2" Exhaust/Pyro(inop), RDT, 265/75R16 BFG/AT on 16X8 American Racing Wheels 138K and still going strong
1983 300SD Turbo Diesel, 3.0L Inline 5, 4 Speed Auto, White/Parchment, VDO Boost Gauge, 215/60R15 Bridgestone Potenza RE960AS Pole Positions on 15X7 15 Hole Wheels, Straight Piped, 298K?
