Diesel Forum - TheDieselStop.com - View Single Post - leaky exhaust manifolds
Old 11-05-2009, 03:23 PM   #4 (permalink)
fxdwgi
fxdwgi's Avatar
Originally Posted by ford_doctor View Post
Some leakage is typical but a leak is a leak. Usually installing the gaskets is the simplest and least expensive option. I say "usually" because you never know when you will encounter a seized bolt that breaks or a manifold that is unknowingly rotted away. Consider new bolts with the gaskets on this project.
A exhaust manifold gasket on a 7.3 ??
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline   Reply With Quote
