Diesel Forum - TheDieselStop.com - View Single Post - air conditioning coming out of defrost only
Old 11-05-2009, 07:39 PM   #10 (permalink)
gcoutlaw
4x4-Defrost issue
As stated initially, I thought it was the hubs so I put on some Warm Premium hubs that I know manually lock or unlock (read some other posts, did not know any better).
Now, with that being done, I have not capped off anything as of yet so I presume I should put a cap on the line inside the fender wells up front where the line connects to the tab mounted to the frame and where that hose goes down to the front axle? Capping this off would maybe help as I guess now I have nothing to pressurize given I just took off the stock hubs? I guess I should also put a cap down on the bottom of the hose where it connects to the axle if I remove that hose to make sure no water or debris gets in there too?
I guess if none of this works, I do the selinoid or whatever behind the firewall?
gcoutlaw is offline   Reply With Quote
