Diesel Forum - TheDieselStop.com - View Single Post - My E40D transmission started shifting unevenly and the "off" light is flashing
Old 11-05-2009, 07:40 PM   #10 (permalink)
midwestconnection
midwestconnection's Avatar
Originally Posted by blageurt View Post
It probably is the VSS which will throw a PO500 code. I changed my sensor and the connector . It still flips out now and then. I need to replace the wires now since there is a connection /connectivity issue. When I turn left hard sometimes it will go off. Spring Time I will deal with it. The sensor is in the rear end on Top. The connector I got from Ford. Good Luck
I sure hope your right. I bought that sensor at Ford for $30 including Tax. My code reader should be here tomorrow, I'm waiting to read the code and hoping it says the PO500 your describing. I'll look at the connector and the wires too. Thanks
I'm not worried about the $30, I'm just hoping that it fixes the problem.
Largely, hoping!
midwestconnection is offline   Reply With Quote
