Diesel Forum - TheDieselStop.com - View Single Post - HPOP question
Thread: HPOP question
Old 11-05-2009, 07:58 PM   #4 (permalink)
Patrick Feeley
Patrick Feeley's Avatar
My Photos: (19)
The early pumps had the anti-drainback valves in the pump. The later ones have it in the front cover. It will work (old cover, late pump), but will drain back causing longer cranking to start. You change to a later front cover (motor has to be pulled) or there is a mod to the older front covers that can be done (I'll have to look for a link), or some have added an accumulator to the system (PM members Nit or Powerstroke2000 unless they chime in on this one). I'm with Bill (get an Adrenaline). Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline   Reply With Quote
