This is DIRECTLY from the warranty manual:
Furthermore, (under emissions warranty), you will not be charged for labor, diagnosis, or parts for any emissions control device or system for 100k (ie no $100 deductible):
Air flow sensor
Air Fuel Feedback control System and sensors
Cold start enrichment system
Electronic engine control sensors and switches
EGR system
Exhaust manifold
Fuel Injection System
Intercooler Assembly - Engine Charger
Power Train Control Module
Turbocharger Assembly
Also covered by the two emissions warranties (Emissions defect warranty and Emissions performance warranty):
All emisssions-related bulbs, hoses, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines and wiring harnesses that are used with components on the list above.
Your turbo replacement should be w/ ZERO deductible also. tell the dealership you will be contacting Ford customer service if they do not agree w/ you:"
Ford Motor CompanyCustomer Relationship CenterP.O. Box 6248Dearborn, MI 481211-800-392-3673 (FORD)(TDD for the hearing impaired:1-800-232-5952)[FONT='Times New Roman', serif]www.customersaskford.com [/FONT]
You can also contact the EPA:
Manager, Certification and Compliance Division(6405J)[FONT='Times New Roman', serif]Warranty Claims[/FONT]Environmental Protection AgencyAriel Rios building1200 Pennsylvania Avenue, N.W.Washington, D.C. 20460
