Diesel Forum - TheDieselStop.com - View Single Post - 4wd Conversion
Thread: 4wd Conversion
Old 11-05-2009, 10:06 PM   #36 (permalink)
44boggers
six speed is same as auto need to have rear output swaped to 4wd shaft
if you decided to go with the newer coil set up just make sure you have everything off the frame suspension related
as far as t case thats up to you as long as you find a manual that shifts smooth and turns good or an ESOF im not sure how to check them
also with the ESOF you need the vaccum lines and tranny t case harness and the dash switch
the wiring for the dash switch shout already be in the dash just dead clipped to the back side of the dash
01 F350 Lariat CC DRW 2x4 Auto (now with 4x4 conversion)
TS chip 50/75/100/120 with PMT1
AFE stage one cross with some k&n fipk parts
Autometer guages (Pyro, Trans Temp, Boost)
Wicked Wheel and TAG 1&2
4" MBRP exhaust (stainless)
Billet grille & 02 headlights
Line-X
PTC triple disc converter, tugger kit, sonnax valves,cooler bypass delete, upgraded internals, suncoast coast clutch drum
future mods:king ranch interior,painted heated signal mirrors
44boggers is offline   Reply With Quote
