In 2004 the design of the piston changed. This required the installation of a shorter glow plug by 1.2 mm. If the longer glow plugs are installed into an engine with updated pistons, glow plug to piston contact will result, ending in potential catostrophic engine failure.
Look it up and post the part number if a glow plug was replaced (and in which cylinder).
Mark
