Diesel Forum - TheDieselStop.com - View Single Post - Coolant Flush - VC9
Old 11-05-2009, 10:39 PM   #14 (permalink)
steel10
It seems like some are getting confused by my procedure. The last flush left 15.5 quarts of distilled water in the system when the pet**** quit draining. I then added 2 gallons (8 quarts) of pure Ford Gold Antifreeze.
8 quarts/15.5 quarts = 52% Antifreeze / 48% Water
I continued filling the coolant reservoir with a 50/50 mixture of Ford Gold Antifreeze and distilled water until the reservoir was full.
I checked my freeze protection using a coolant tester and it indicated that I was slightly over a 50/50 mix as was indicated by the freeze protection of ~-42deg F. A true 50/50 mix will yield a -34deg F freeze protection.
Cody
steel10 is offline   Reply With Quote
