I just got it too. I've had the truck since '02 and I'm not all that worried yet. I am wondering that since they have to open up the brake system on the truck if they will completely bleed the system including the abs unit. I'd like that. What I don't like is the fact that I haven't had the CPS recall done nor do I want it done. I really don't like the fact that someone else has to drive my truck too.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
