Not sure on actual fitment, but just swapping headliners will get you nothing more than holes in the headliner where those nice grab handles used to go. What you'd need to check is if there is enough metal in the roof of your truck to support those grab handles so they have somewhere to get bolted to.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
