Diesel Forum - TheDieselStop.com - View Single Post - still getting CEL after installing boost relief valve
Old 11-05-2009, 11:05 PM   #5 (permalink)
BTBBT
My Photos: (19)
Mine does that too. I don't have the boost fooler or anything, but it'll do it with less than 15psi. I just installed a HPOP pressure gauge and that thing will stay low for a long time and then I get the light. It'll stay on for a while and then go off. That's probably what's happening. Your tune is firing your injectors faster than what the stock HPOP can handle. I guess you could do one of three things. 1. just drive it and don't worry about it (mine's been that way for a couple of years now). 2. get a new tune that will fix the issue. 3. Get a better than stock HPOP and never look back!
Like I said, mine's been doing it for close to two years now and it hasn't seemed to hurt anything. I would like to get an Adrenaline HPOP but I just don't have the money right now.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline   Reply With Quote
