Originally Posted by ctdBCB
does the cab have to be removed? and if so what about just to put studs in the head and not remove it?
yes cab off to do gaskets,,,,made to remove cab as bolts up from botom,also i am doing studs and new gaskets as block surfacs are same as 6.0 and rust badly.........anyone know if any aftermarket head gaskets with a built in fire ring as stock does not have one ,,,they are almost identical as the 6.0 gaskets............have cab off of 2004 6.0 and compared gaskets from 6.4 kit and vertualy same.....hope this is not the start to a nother 6.0 fiasco!
1996 F350 CREW CAB,37"tires,2003 hpop,160CC injectors,electric fuel system.malery pressure reg.6.0 intercooler,sd bd turbo,sd 3 in intakes ,tw 4 pos. chip,gauges,tcc disconect,mod.e4od,rear detroit,20,000remote cooler,baja fiberglass body panels,stage 3 methanol...............
