Diesel Forum - TheDieselStop.com - View Single Post - PowerSteering Fluid, Type ?
Old 11-06-2009, 04:01 AM   #7 (permalink)
boomboom
boomboom's Avatar
Originally Posted by Matt0987 View Post
The owner's manual reads;
CHECKING AND ADDING POWER STEERING FLUID
Check the power steering fluid.
Refer to the scheduled maintenance
guide for the service interval
schedules. If adding fluid is
necessary, use only MERCON ATF.
If you need an owner's manual you can get it from;
https://www.flmowner.com/servlet/Con...OwnerGuidePage
YA , manual also says only use straight mercon in trannies too and look how long that lasted Just use whats in your tranny. You do know whats in your tranny ? Hope to GOD it aint type F !! P.S. I'm trying to be funny, not a JERK
boomboom is offline   Reply With Quote
