Diesel Forum - TheDieselStop.com - View Single Post - 4x4 not working
Thread: 4x4 not working
Old 11-06-2009, 07:13 AM   #4 (permalink)
bismic
Edit - are your hubs not engaging or is it your transfer case that is not engaging?
If you have the defrost coming on when it shouldn't, you have a vacuum leak somewhere (behind the glove box, at a hub or two, or at the heater control valve)
Mark
bismic is offline   Reply With Quote
