Diesel Forum - TheDieselStop.com - View Single Post - EGR Cooler -Engine Failure - *PICTURES*
Old 11-06-2009, 07:18 AM   #32 (permalink)
johnny87
Originally Posted by Gofasterdammit View Post
When was the truck apart last and who did it? That is a foreign object, it's real easy to drop something down the intake ports on the cylinder heads. My best guess is whoever had the intake manifold off (or EGR valve, ect) dropped a bolt down there. If the object finds the right spot it can get stuck in the intake manifold for a while, work it's way to the intake valves where it gets worn down until it's small enough to fit past the valves and into the cylinder. Ford is denying warranty coverage because a Ford part did not fail. You said the dealer fired the last tech for incompetence, well there you go. It's the dealer's responsibility (or whoever had it apart last) to fix it.
That makes a lot of sense as well. I would say letter to Ford with the pictures as well as the fact that the Tech was fired for cause. You may still need the attorney as well though. I have no idea how much control Ford has over it's dealerships in that regard. If you could prove damages stemming from your truck being in their shop for a month.... that has to be worth something.
On a separate note I can somewhat understand Ford's stance on this one but I do feel that protecting their truck customer would be in their best interest here. There has to be somebody at Ford that controls the dealership to customer complaints probably different from warranty claims.... I'd want to talk to that guy.
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
johnny87 is offline
