Originally Posted by scootdog
disconnect both batteries, then connect them, i gots over 200,000 miles on my `97.
mine said trans slip? it has done it 2 times in about a year. going in next week for a trans rebuild. its still running fine, i just don`t wanna get stuck out somewhere....
If you don't know about that $27 sensor that is bolted onto the rear end and that a five year old could change in ten minutes you might want to consider it. The shop will of course rebuild the transmission for you and charge you a few thousand dollars and not tell you nothing about that sensor. -- 200,000 miles is nothing unless you pull heavy.
Thanks for the battery tip. I will try that.
