Originally Posted by hhall1114
I had a similar problem your discription sounds pretty close, grab your drive shaft at the carrier bearing (right in the middle of the drive shaft) if it moves back and fourth a bit your carrier bearing is shot.
It does move up/down a little inside the metal bracket.
Try it front/back?
How does it come apart?
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
