Originally Posted by CDX825
Your on the right track. Now that your EGTs are lower you will be able to add more fuel and get more power. Just don't want to go to high as you will melt the pistons.
Where is the probe mounted for the pyrometer?
abouttwo inches after the turbo, the DT has a cast down pipe from the turbo to the exaust pipe itself, i drilled and tapped for the probe
thanks for the input still need some pump info anybodyknow these pumps?
