Diesel Forum - TheDieselStop.com - View Single Post - Leaking oil pan
Thread: Leaking oil pan
Old 11-06-2009, 10:22 AM   #3 (permalink)
pigsbreath
since you posted under 6.0L WILL ASSUME ITS A 6.OL
need to disconnect engine mounts
raise motor off frame
remove pan bolts
slide pan rearward
remove two bolts to pick up
remove pan
FEBRUARY 2004 F350 CREW DUALLY,60K, 6.0L/6 SPEED/3.73/2WD,
EGR SPOOL, INSULATED WRAP CAC,BUTTERFLY DELETE,ACCUFAB INLET ELBOW,MUFF TUBE,BED COVER,BREATHER VENT MOD,OB1308 BY-PASS FILTER BASE,upgrade fuel return pressure spring 30# increase, velvet ride shackles, tranny cooler/filter,COOLANT FILTER,redline wetterbetter,1704A SUPERCHIP, SCHAFFERS 9000, 22MPG EMPTY @ 55MPH in cruise. Last fill up calculated @ 18mpg Hobbies- sticking my head out the window like a dog and hauling ass on the scooter rain or shine
pigsbreath is offline   Reply With Quote
