The grill cover works great. I live in Ma and used it last winter for the first time and it really makes a difference with warm up times. Also it protects mainly your aftercooler, also all the other coolers up front, from all the sand and salt on the road from getting kicked up and lodged into everything. There is still the open area in the bumper cut out, but the cover helps alot.
And the snow finds its way into the air cleaner by way of a snorkle that comes out of the filter housing and runs along the inside of the fender and ends about 6 inches behind the headlight. If the snorkle was not there, much like a did on mine and made a custom set up, you would not have to worry about it.
