The temperature you need to monitor for not melting your engine is the engine exhaust gas temperature, not the turbine exhaust temperature.
A turbocharger works by pulling energy out of the exhaust gas. The turbine outlet temperature will be hundreds of degrees lower than the turbine inlet (engine exhaust) gas temperature.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
